GoPro Hero5 Session Teardown
Hello Community,
i’ve got a broken GoPro Hero5 Session (Device is not on here yet) and i want to open it up. Some guides show, that the Hull at the side of the lens is only glued and can be opened after applying some heat. I have access to alle the equipment needed (heat gun, rework station, tools to open smartphone cases) to open it up but i don’t know which duration and settings i need at the rework station for example. The teardown guide on this website of the Hero4 Session is way to brutal. :’D
Can someone with the knowledge of rework stations give me some hints about tackling this glue issue?
Update:
It seems the results differ from Cam to Cam. I’ve seen some people getting it open with their rework station set at 350°C. Somehow mine won’t budge even a little bit by that temperature so i’ve startet tearing it open. Next issue is not destroying the boards which hide directly beneath the outer hull.
Will update again when i get that candidate open. There should have been other ways to get this thing that sturdy…
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
