メインコンテンツにスキップ
Repair guides for the Samsung J7 Pro. Learn how to repair your Samsung J7 Pro on your own.
How to recover deleted photos from Samsung galaxy J7
How to recover deleted photos from Samsung Galaxy J7? All photos on my phone are deleted by system error. How to recover them? Pls help.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 7
5 件のコメント
Someone has theft my old phone samsung j7 in tirupathi November 19th 2019. I want my old photos, videos in the Samsung phone pls help me . How can I recover all the data in my old phone pls answe
さんによる
I deleted my photos on my galaxy J7. How do I recover without a computer
さんによる
Need to get my photos back on my phone
さんによる
How to recover permanently deleted photo of Samsung j7
さんによる
@sajansewa2
If there is no backup, you may need a professional data recovery app for Android to scan the device memory to see wether you can find wanted data from the results.
さんによる
コメントを追加
4件の回答
最も参考になった回答
If the deleted photos saved on sd card, first stop using it in case of data overwritten. Then connect your Samsung Galaxy J7 to computer via usb cable. Here, you can use Coolmuster Lab.Fone for Android to scan it. If the deleted photos can be scanned out, you can recover them back easily.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Try out the latest images recovery process in phone samsung galaxy j7
さんによる
If you didn’t have a backup, you can use an Android recovery tool to restore the deleted photos. But you’d better stop writing new data on your Samsung galaxy J7. Good luck.
さんによる
コメントを追加
Do you have Google photos sync with your gallery? Or do you have Samsung cloud on and sync?
If not,you can access them from internal storage,the only method is to use some photo recovery program that have method to detect the internal storage.
It is worth mentioning that with you have to make sure that the photo are not overwritten by new files before recovering.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Did you save the photos to an inserted SD card? or phone memory?
If SD card, stop adding new files to it, such as stopping taking photos or downloading files. If phone memory, you’d better stop using the phone right now, because new items will be generated when the phone is in use.
Recover photos from SD card
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
EaseUS Data Recovery Wizard Crack may damage your computer. Get the official EaseUS Data Recovery Wizard Crack. EaseUS data can be recovered with a serial number in two ways.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
roycejane58 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 12,560
