メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
iPhone 7 baseband problem
Please help. After repairing the audio system on the iPhone 7, the phone lost its network. He stopped showing the IMEI number.
I was able to desolder the baseband and clean the main board from the remaining glue. Many solder pads have been removed, but these are NC fields.
I have obstructed the system twice and, unfortunately, the IMEI number is still missing, the phone has been uploaded and 3utool displays error -1 at 80%. On one forum, someone said that he sees the problem in the picture, but he does not want to provide information on what the problem is. Thank you for your help.
Update (01/10/2019)
Unfortunately, there are so many servants in Poland who are happy with someone's problem.
I have checked the capacitors and have no short circuits.
On the voltage coils as in the attached picture.
Thank you for your help, I do not hide that I did it for the first time and it would be nice if the phone started.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
4件の回答
ベストアンサー
What kind of person would frequent a public forum on repair, leech information from others but not share knowledge themselves? They’re either full of it or (insert your favourite adjective here ;>).
Looking at your picture quickly, the pull looks pretty good. I would double check all of the pulled pads to insure they are NC. Also, inspect the right hand side where we can see some scratching while you removed underfill. Insure it doesn’t damage any traces. Also check the components at the top, they may have been damaged during the Audio IC repair or during the BB removal.
Check all the caps around the BBPMU to see if any of them are shorted.
The Audio IC repair, while presented as a routine repair, is truly one of the more terrifying repairs out there because so much can go so wrong, so quickly. This is especially true on the Intel BB boards as there is so little information available out there.
このアンサーは役に立ちましたか?
スコア 5
4 件のコメント:
Hi @refectio @boneksl I'm not an iPhone repair technician but had quite similar problem. My iPhone 7 (A1660) got no service, brought it to a repair guy and he reballed the baseband IC and the problem still exist. iPhone can't be activated because IMEI is not showed up. He said that the CPU IC might already weak and there's no other solutions, otherwise I have to replace the logic board.
I'm just looking for another opinions from you, is it true that if the BB CPU is broken then there's no other solution?
Thanks
さんによる
Hello @iqnaul, that is correct. If the Baseband CPU is damaged internally, then it cannot be replaced as it is code-locked with the CPU and cannot be re-programmed.
さんによる
Thank you for your explanation @refectio I think I'm going to just sell my iPhone at very low price.
さんによる
is a common failure when repairs audio ic, thats cause due to a wrong pointing of the hot air flow to the bbpmu thats located next to the audio ic, so the solution is to reflow that ic,if still not works you will have to reballing it or replace it.
さんによる
コメントを追加
First check BBPMU then BBcpu.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
yes first check short around bbpmu as gsm solution said and the change the bbpmu reballing bbcpu is the last option left .
さんによる
コメントを追加
This is actually a faulty baseband ic that can (I don’t know if it’s visible that you repaired your iPhone) be replaced free by Apple. It’s for the A1660, A1779 and A1780.
The baseband is wrong produced in these models so it needs to be replaced by another baseband chip by another make.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
have same problem ip7 intel, error cant accept baseband data after i have for reball bbcpu,
no short at bbcpu, n then i have all check pads of bbcpu n bbpmu have no short all diode measure is same, after that still same, error can’t accept baseband data, no imei keep searcing no service before i have reball bbcpu n bbpmu only triangle on the corner now have searcing n no service can help me
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
boneksl さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 23
過去 30 日: 92
今までの合計 36,296
