Where is the intake runner postion sensor located
need to replace intake runner position sensor
If it’s an error code p2015, It’s on the right side of the intake. There can be many reasons for it failing. It can be bad, jammed, gunked up with carbon inside the intake, broken actuator arm, etc. Make sure it’s moving correctly before replacing the sensor. Manually actuate it by hand.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 58
