メインコンテンツにスキップ
Repair information and troubleshooting for the Dell Latitude E6430. This business class laptop has a 14 inch screen and uses a 3rd generation Intel Core processor. It was announced in May 2012.
9回答 すべてを表示
Bluetooth not working on Dell Latitude E6430
On my Dell Latitude E6430 (Windows 10 Home x64 ) I cant find a setting for Bluetooth. In the BIOS Bluetooth is enabled. When I try to install drivers it says activate Bluetooth using wireless switch, but the switch is on.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 6
2 件のコメント
Hi,
What is the status of the Bluetooth adapter in Device Manager?
Right click on Windows start button and select Device Manager > Bluetooth
If it is not listed click on View > Show hidden devices in Device Manager and check if it now appears.
Have you tried Windows Troubleshooting to check if this resolves the problem?
Go to Control Panel (click on Start button and then type Control Panel in the search box and select the Control Panel app option) > Troubleshooting > Hardware and Sound > Bluetooth
さんによる
Hello,
When I pressed show hidden devices Bluetooth showed up b ut when I clicked Dell wireless 380 Bluetooth module it said"to fix this problem, reconnect this hardware device to the computer."
When I go to the control center there is no Bluetooth option.
さんによる
コメントを追加
4件の回答
ベストアンサー
Hi,
Try uninstalling the Bluetooth device in Device Manager (right click on Bluetooth entry) and restart the computer to check if it finds and installs “new” hardware
If it still doesn’t work, here’s a link to the service manual for your computer.
Scroll to p.27 to view the necessary pre-requisite steps and then the procedure to remove the Bluetooth card. This is just to see if it is seated correctly.
このアンサーは役に立ちましたか?
スコア 5
3 件のコメント:
Hello,
I uninstalled the Bluetooth driver and restarted, the PC didn't detect anything.
さんによる
Hi,
If the Bluetooth hardware entry is no longer showing anywhere in Device Manager (check hidden devices and "Other Devices" entry) and you have verified that Bluetooth is enabled in BIOS you may have to check that the Bluetooth card is connected correctly to the motherboard.
Use the service manual (see link in answer) and scroll to p.27 to view the necessary pre-requisite steps and then the procedure to remove the Bluetooth card.
If it appears to be connected OK it may be that the card has failed as it should be detected by the OS on startup. This doesn't mean that it will work as there may be software problems but it should show up in Device Manager.
The card is relatively cheap to replace. Here's a link to a supplier just to give you an idea of the cost of the part.
There are others online that may suit you better.
Just search for Dell Wireless 380 Bluetooth module to get results.
さんによる
That's not working
さんによる
コメントを追加
For information on how to pair (connect) Dell Bluetooth® enabled computers to Dell Bluetooth accessories, and steps to resolve issues you may see, refer to the article below.
https://www.dell.com/support/article/us/...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
The bluetooth only works when wifi switch is on, can't use it when connected with ethernet. I had same issues mentioned before, I found the bluetooth in hidden devices and I enabled it. Once enabled, I could turn it on and off moving the wifi switch and clicking the option turning the adapter on and off.
Too much trouble, especially because I use ethernet, so I just ordered a bluetooth adapter.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
There are 3 most common reasons if your dell Bluetooth driver not working -
  1. Too many devices are connected
  2. Corrupt it outdated Bluetooth driver
  3. Device not in range or not in pairing mode
I can suggest you two methods - Manual or Automatic.
Manual processes it time-consuming and there is a chance for mistakes. I will recommmend for the automatic process, This is less time-consuming and, when your drivers will be outdated, you will get a notification to udate drivers automatically.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Panayiotis Michalos さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 67
今までの合計 11,621
