Why does my shark iron temp setting light keep changing?
My shark iron is only 4 months old. When I set the temperature control light, it will not stay set. It runs up and down and may even turn itself off.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi @littleproblems ,
It appears that there may be a problem with the temperature sensor in the iron.
There is a 12 month manufacturer’s warranty on the iron.
As the iron is only 4 months old, I suggest that you contact the manufacturer as per the details in the manufacturer’s warranty statement that should have come with the iron, as to what to do to make a claim for a manufacturer’s warranty repair or replacement.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 2
過去 30 日: 10
今までの合計 849
1件のコメント
My iron does the same thing and has done this since Day 1. The steam doesn’t always work either. I thought it was something I was/wasn’t doing right. I’ve had my iron for over a year.
sunnybrook6905 さんによる
