pin broke off in dc plug
the male part of the dc power plug broke off in my laptop any suggestions on getting the pin out
この質問は役に立ちましたか?
この質問は役に立ちましたか?
In my experience tweezers and pliers work the best- just wiggle it around and stuff, not very difficult. The unfortunate part however, is that the female end may be or become damaged.
このアンサーは役に立ちましたか?
Remove the battery, then try to use a pair of tweezers to pull the plug out, or see if you can use superglue and glue a screwdriver to the plug and pull it out. If that doesn't work, then you will have to place the DC-In Board.
このアンサーは役に立ちましたか?
Never heard of the superglue one before! Sounds like an idea though.
It's not easy to remove the DC-in from a PowerBook, but if you do take it out, it's possible to straighten out a paperclip and use it to push the broken pin out of the plug from the inside. This is most effective with iBook DC-ins, especially because iBook DC-ins aren't nearly as hard to get out of the laptop. Once the DC-in is out, it's generally possible to get the paperclip in there from behind and push the pin out.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 18
今までの合計 3,925
