メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
iPhone 5s has multiple lines on screen after multiple LCD replacement
My old screen was damaged and the battery was not performing well, so I had it replaced. However, after replacement, I have discovered that the new battery was draining so fast even on standby. I had no choice but let the repair guy put back the old one. Then a problem occurred — when the LCD was put back in the phone, multiple vertical white lines in different thickness appeared. The guy doing the repair had the LCD replaced by two new ones already but still the problem does not cease to exist. Is it still a problem on the LCD? What’s causing those vertical lines?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
I believe that since after multiple LCD replacement attempts did not solve the issue the attention should be focused on the logic board side..it might be a connector pin got damaged or one of the surrounding components in the area. Unfortunately that would need microsoldering skills and tools and might not be economically advantageous on a 5S iPhone.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Damaged the LCD connector or components around it.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
ira さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 73
