メインコンテンツにスキップ
Device and repair information for the 60" LED HD TV by Samsung released in 2013, model number UN60FH6003FXZA.
203回答 すべてを表示
Standby flashes, backlight flickers, repeat every 10 seconds
This isn’t my exact model, but I have one that is extremely similar. When I plug the TV in, it it immediately tries turning on, the standby light blinks and the backlight kicks on, changes the brightness a couple times, then turns off. This cycle repeats indefinitely, without pressing a power button on either the TV or remote.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Cody Mort  we will need to know your exact model number. If it turns on when you plug it is then it is most likely the button bar/IR board or the power board. Remove the back of your TV and take a good look at all the boards. Check for obviously damaged components like leaking/domed looking capacitors and IC’s that are partially melted etc. Post some pictures of your boards with your question so that we can see what you see. iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Cody Mort さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 7
過去 30 日: 8
今までの合計 389
