メインコンテンツにスキップ
2015年9月25日に発売。モデルA1687/A1634。このデバイスの修理は前モデルと似ています。スクリュードライバーとこじ開けるツールが必要です。GSM もしくは CDMA。容量は16、64か128 GB。カラーはシルバー、ゴールド、スペースグレイ、ローズゴールド。
1041回答 すべてを表示
6S Plus Rear Camera - Left side not focussed
6s Plus, restored via DFU, the camera is shaky (I know this is a known issue with the OIS) and I have replaced the camera, the replacement did exactly the same so either something else is wrong or I got a dodgy camera.
However, I’ve noticed that the camera has no problems focusing close up, within 10 inches or so, however when focusing over 3 feet it struggles to focus (when its not shaking!), the left side is extremely blurred but the right side is actually in focus.
wondered if anyone has come across this? I’m reluctant to change the camera again
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Indeed, this could be a bad replacement camera…or a logic board issue. The challenge when troubleshooting iPhone issues is that you need to have access to high quality, known good parts. Unfortunately, Apple doesn’t want to play ball here and refuses to distribute high quality replacement parts to third party shops. Some vendors, like iFixit, do a tremendous job at quality control but the whole “iPhone replacement part” ecosystem suffers from crap parts noodling their way through the supply chain.
Beyond trying another camera, my feeling here is that one of the many voltages used to power the camera and the OIS system may be damaged. A little probing would confirm this possibility so if you have a local shop that does micro-soldering work, they may be able to help out.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Josh さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 53
