メインコンテンツにスキップ
The Dell Venue 11 Pro is a flexible slate tablet built for business. It comes with many work-oriented features, including Windows 8.1, a removable battery, and a variety of docking solutions.
11回答 すべてを表示
My Dell Venue wont "Boot"
I recently went to power on my tablet (it only turns on half the time and when it does) it gives me an all black screen with some words in the corner saying “no bootable devices found" and “run a diagnostic check". I ran the check and nothing was wrong aside from something with the harddrive, yet it still said everything was fine when the test was complete. It was working just fine a few days ago. The only thing I think could be the problem is I've been using an undersized power adapter, since as soon as I got the tablet for Christmas (which was last year, by the way) the charger broke and I had to buy a new one. The only thing I do on that tablet is draw and make art, and occasionally watch videos or listen to music. Can anyone help me? I don't want to pay hundreds of dollars to fix the stupid thing.
Thanks,
Charlie
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
It needs a proper sized power supply. It seems like it was gradually draining down the battery. If you leave it charging for a couple days, it should run fine for “some” time. I’ll also wager the supply was getting hot, which usually degrades it’s output. If the problem persists, you’ve got a harddrive problem, well past the scope of answering here. Find qualified help.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Charlie Reddick さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 93
