メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
Why my battery draining fast and phone gets warm
Why my ip 5s phone draining battery so fast even known good battery i think something shorted out the phone charges battery well but something strange when its turned off ,its not automatically boot when connected to charger i should push power button 1st then it detect the charge. Is it u2 defect symptom?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Has anything happened to the phone recently, such as a drop, repair attempt or water damage? Battery drain can be caused by a defective battery, broken charge circuit or defective peripheral (screen, camera, sensor, flex etc.) . Depending on the history of the device, it could be anyone of those causes.
If you have tried a known-good battery, then try a known good screen to see if that helps. If not, progressively remove peripherals until the problem is identified. Eventually, you may have only the logic board left which would point to a logic board issue.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I already tried changing battery,lcd,front camera flex,home button flex i will try changing port later
さんによる
And why my iphone didnt turn on immidiately when it connect to power is it board issue?
さんによる
コメントを追加
回答を追加する
azmi muwahid さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 56
