Dirty Ports?
There is a lot of buildup of dirt on the case where it recesses into the port openings. Is it a problem and what is the best way of cleaning it?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
use q-tips or compressed air to try and clean the ports
as for it being a problem there shouldn't be one as long as it doesn't mess with the connection
このアンサーは役に立ちましたか?
Its too stuck for compressed air but i will try the q tips
If the muck is really stuck on, you can use a small amount of alchohol on the Q-tips to help unstick it.
このアンサーは役に立ちましたか?
Q-Tips or dry cotton wool should clean your ports well.
As for the mag-safe charger port, the magnetism can hold some dirt to it. This can be hard to remove but Q-tips and a little extra effort should clear it out
このアンサーは役に立ちましたか?
A soft toothbrush can be used to loosen debris, then use a little compressed air to blow it out. If you are going to use alcohol, be sure to remove the battery first, to avoid shorting anything out.
このアンサーは役に立ちましたか?
I advise against alcohol, if it get's in the port- your port may end up permanently screwed. Ditto at the compressed air though.
このアンサーは役に立ちましたか?
Used a clean make up brush and that did the trick of removing any sand, dirt, lint from the charging port
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 8
過去 30 日: 20
今までの合計 11,311
1件のコメント
I used a blending/ fluffy make up brush and that did the trick. Soft, clean and easy to get. I found it easier to use then the q-tips
emita_sakura さんによる
