メインコンテンツにスキップ
1.8 GHz デュアルコア Intel Core i5(Turbo Boost使用時最大2.8 GHz)3MB L3キャッシュ
371回答 すべてを表示
How to test if logic board or battery is issue? (MB Air 13" mid '12)
My MacBook Air Mid 2012 recently stopped working unless plugged into the charger. The battery appears to have disappeared, though Apple Hardware Test doesn’t find any faults. Coconut battery doesn’t find anything and the System Information produces:
Battery Information:
Charge Information:
  • Charge Remaining (mAh): 0
  • Fully Charged: No
  • Charging: No
  • Full Charge Capacity (mAh): 0
Health Information:
  • Cycle Count: 0
  • Battery Installed: No
  • Amperage (mA): 0
  • Voltage (mV): 0
SMC and PRAM resets have done nothing. Does anyone have any experience in whether this is likely to be a battery or a logic board issue? The battery was replaced in May with a third party battery. Is there another test I can do other than buying another battery?
Thanks,
Sam
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
The micro controller within the battery is not responding!
Which is why the system is not seeing it. Sorry, you’ll need to replace the battery. Given the age of the system it’s likely well worn as well.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Cool: thanks. I wasn't sure which it was.
I realise the system is old, but it is a favourite!
さんによる
コメントを追加
回答を追加する
Sam さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 113
