Where can I find a battery replacement
My battery is running around 50% as good as new and was wondering where I could inquire about getting it replaced soon.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
According to this website the Google Pixel C is a discontinued product and therefore compatible replacement batteries may be hard to source in the future due to lack of sufficient or compatible devices to justify continued manufacture of that specific battery. This has happened in the past with other discontinued products by different manufacturers so it is not improbable that it may happen with yours as well Just something to bear in mind.
Looking at Step.13 in the ifixit Google Pixel C Teardown guide, the battery model number is C1552B (see image).
If you search online for C1552B battery, you will get results for suppliers of the part.
if you decide to replace it yourself, according to the script in the teardown guide it is not an easy thing to do, as it is very strongly adhered to the case and they didn’t want to risk an explosion by overheating it in trying to remove it. Just so that you are aware of this.
(click on image to enlarge for better viewing).
If you do not wish to replace the battery yourself just search for Google Pixel C battery replacement to get results for repair services who will do the battery replacement
このアンサーは役に立ちましたか?
Battery removal is not covered in the breakdown. Gentle heating with a metal "spatula" behind each battery affords a relatively easy release. I'd like to know how to reconnect a replacement set without gluing the connector in.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 11
今までの合計 2,575
