メインコンテンツにスキップ
A tablet with capabilities to attach to a portable keyboard and function as a laptop.
16回答 すべてを表示
bios not detecting hard disk
Ok, I have a Lenovo Flex 4 15" 2in1 laptop which I had two years but after the first year it would not fully load maybe because of connection, (maybe). Yes it will still power on. Now after some time I realized my Bios setup did not recognize are was not communicating with the hard disk . At first, thought hard drive was bad but it wasn't. Have anyone had this issue and can help me. Your help will be a blessing too me.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
4 件のコメント
When you turn on your computer, it show you a message like no hard drive detected ?
さんによる
no just the name of my laptop
さんによる
Have you tried to set default settings of the BIOS ?
さんによる
when i go to bios it keep asking for password which i do not have
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Alternatively, you can try manual methods to fix this error, but if they do not help, then you need to change the Hard Disk.
Check the data cable
Check the Jumper Setting
Check for Auto Drive Detection
Check if the Drive is spinning
Generally, if the hard disk is not recognized by the BIOS, you have a hardware failure. For example, the Hard Disk is dead. In this case, you’ll need a new hard disk.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
WILLIAM WALKER さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 126
