Why is my washer not cycling properly?
Hello all.
I could not find the Amana ropmload washing machine I actually have but this kenmore looks similar. My washing machine is an amana with a lid lock and the cycle lights that show where the wash is.
So for the past month my washing machine in my apartment has been acting up. I am not sure if we lost power or something but it worked fine before. When it first happened the washing machine would run fine when starting a load, but would get stuck right before final spin. The clothes would be soaked. I could move the dial to drain/spin and it would normally finish everything, but sometimes I had to do this twice. I tried resetting the motor by using the unplug and open method. Now the washing machine will pause for like 5 minutes after starting before water will come in and the wash starts and it still gets stuck before final spin. I just wonder why I can manually move the dial and it will work, but the cycle won’t go through like normal?
5 件のコメント
Hi @surberus4 ,
What is the model number of the washer?
jayeff さんによる
It is an Amana NTW4610YQ0
Brandon さんによる
No it is Amana NTW4605EWO
Ernestine Robertson さんによる
This washing machine is not following through on cycles,
This washing machine is not following through on cycles, the machine fills with water but will not go through the rinse and spin cycles.
