メインコンテンツにスキップ
Repair information and guides for Amana dryers.
4回答 すべてを表示
My Amana dryer has power and the light comes on but it won’t run
My Amana dryer model number NDG5805AWW  was working fine but when I went to put the next load of clothes in the dryer it wouldn’t run. The light was on but when I pushed the knob nothing happened. I replaced the thermal fuse and pushed the knob to test it. It came on and ran. I opened the door to shut it off but a half hour later when I went to put clothes in it and run it, it wouldn’t run . Any suggestions?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
@newfie13
double check your repair and make sure the thermal fuse is good. Check the door switch as a first cause. here is some more information about possible causes,
Will not start or run:
• All wires are hooked up to their corresponding terminals.
• Dryer is plugged in.
• Blown fuse or circuit breaker.
• Door switch functional...door closed. Check for error code 3
(See Table for code definition).
• Start/Pause rotary selector dial functional.
• Control Board operational.
• Drive motor functional.
• Check motor winding resistance.
Here is the manual for your dryer. follow the troubleshooting as outlined on page 10 Let us know what you find.NDG5805AWW SM
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Cause 1
Thermal Fuse
The thermal fuse is a safety device designed to protect the dryer from overheating. The fuse is located on the blower housing or at the dryer’s heat source such as the heating element on electric dryers or at the burner on gas models. The fuse should be closed for continuity meaning it has a continuous electrical path through it when good. If overheated the fuse will have no continuity meaning the electrical path is broken and the fuse has blown. A multimeter can be used to test it for continuity. Be aware that a blown thermal fuse is an indication of a restricted exhaust vent from the dryer to the outside. Always check the dryer venting when replacing a blown thermal fuse.
Cause 2
Start Switch
To determine if the start switch is defective, attempt to start the dryer. If the dryer hums but does not start, the start switch is not at fault. If the dryer does not respond or make any noise, the start switch could be at fault. Use a multimeter to test the start switch for continuity. If the switch does not have continuity, replace it.
Cause 3
Door Switch
The door switch activates when the dryer door is closed. On most dryers, the door switch makes an audible clicking sound when it activates. To determine if the door switch is working, try starting your dryer and then listen for the “click.” If the door switch makes a clicking sound, it is probably not defective. If you don’t hear a click, use a multimeter to use the door switch for continuity. If the switch does not have continuity, replace it.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Angie さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 22
今までの合計 3,914
