メインコンテンツにスキップ
15 inch "Desk Lamp" iMac G4 700MHz M6498 PowerMac 4,2
32回答 すべてを表示
When powered on, fan spins loudly but no sounds
When I hit the power button on the computer nothing happens, other than the fan spinning up loudly. No other lights, and the monitor don't turn on. Can somebody please lend some insight? I just ordered a new pram battery as per some other answers I've read. I was thinking of replacing the logic board but want to know if anybody has anything else I can try out first. Also, can somebody please tell me how to disconnect the "TMDS video connector"? I don't want to break anything :s I've included a picture of the cable I'm talking about, in case I'm not referring to it correctly.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
The connector has a plastic U shaped cover over it. There's a sticky strip on one side. It will pop off if you wedge a small flathead under the edge. Unplug the machine and all peripherals and hold down the power on button for 10 seconds, then plug it back in and try to start. If this fails, wait for the PRAM battery.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Awesome, thank you very much for your help! Holding the power button didn't seem to work, however. I'll let you know if the new battery fixes it. Thanks alot!
さんによる
コメントを追加
回答を追加する
Armando さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 252
