メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Bose Wave Radio AWR1-1W(別名:Bose Wave Radio I)は1993年に発売されました。高性能ステレオチューナーと2つの独立したアラームを備えた卓上型AM/FMラジオシステムです。
My cd player not working properly
HI I have a bose model AWRCC1 I am having problems with my cd player. I have used a lens cleaner with brushes to clean it It will work for a cd and as soon as I put in another cd it will start to skip again. Can you give me some advice please or recommend someone to repair it . I live in Niagara Region Ontario Canada thanks Benny
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 7
2 件のコメント
I have a Bose Wave which cd player does not work. When I put it, reads but shows the message “Not Playable”. I have tried everything: clean the lens, unplug for cord, reset, tried to plug away from electronic devices. Literally EVERYTHING!!! Radio is good, no problem. Interesting used to work very well. Someday started not reading the CDS. I have brand new ones and does not wok.
What else I can do before smash this sound, which I love… ;-(
さんによる
How to increase brightness on visual display?
さんによる
コメントを追加
1 件の回答
最も参考になった回答
The brush may remove any dust on the lens, but there is often a film as well. Use a cotton swab with some alcohol and gently clean the lens. Do not apply too much pressure as the lens is held in place with very fine wires. If the brush helps to allow a CD to play, the cleaning should be a bit more effective.
Report back with the results of the cleaning.
Dan
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Cleaning the lens w/ rubbing alcohol on a soft cloth fixed the problem! The CD player works perfectly. Thank you, thank you, thank you.
さんによる
I have the simular problem and it still does not play any CD's
さんによる
コメントを追加
回答を追加する
mbdalessio さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 19
過去 30 日: 70
今までの合計 8,329
