メインコンテンツにスキップ
Repair and disassembly guides for GE Microwave ovens.
349回答 すべてを表示
Power goes off to microwave
Power goes off to microwave. Bang on side with my hand where control panel is can usually get it to come back on. Sometimes will work fine for little while other times power goes right back off GE adora model. Dvm7195sf1ss Any ideas what could be the problem?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
4 件のコメント
If your circuit is overload the breaker on that circuit will trip too much is on that breaker. You may need to call an electrician to see if your wires can use a higher amp breaker.
さんによる
Thanks for your response
さんによる
It doesn’t cause a circuit breaker to trip
さんによる
I am having the same problen
さんによる
コメントを追加
2件の回答
ベストアンサー
I’ve looked at this question about five times and really didn’t want to answer as I didn’t want the responsibility of you getting knocked on your can from the high amperage stored in this thing. You obviously have a bad electrical connection. Could be a loose wire or cold solder joint. Personally I would not risk trying to repair it.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Thanks fir your response
さんによる
コメントを追加
I had the same exact problem. On the pcb it was a weak solder on one of the pins of the low voltage transformer. Took 5 minutes to re-solder it. Also, a dirty micro switch on door. Took another 30 minutes to take apart & clean. Now the microwave works great
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Glenn kreutzer さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 16
今までの合計 518
