メインコンテンツにスキップ
Repair information, service help, and troubleshooting/diagnostics guides for Bosch refrigerators.
15回答 すべてを表示
Remove Dispenser from Freezer Door on Bosch Refrigerator B20CS80SNS
The water line broke near the hinge in the Freezer door and I need to replace. I removed the face plate of the dispenser, removed the circuit panel, removed plastic cover , removed the 12 screws around the dispenser unit. However the unit will not come out it appears to be still attached somehow. I can’t find any more screws that need to be removed.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
My line broke right under the freezer door where it curves. I tried to pull it out to put a connector on, but it broke off. I wound up getting an elbow from Home Depot where one end was able to be pushed into the water line. The elbow had a connector which I was able to use some tubing to connect to the main water line, but I had to add a reducer connector to the main water line to make it work.
Now my flab in the ice chute is broken and I am trying to get the façade off. I did find one little slot on the bottom left and i used a small screw driver and have the left bottom side off. Going back to get the whole thing off - hope its not too hard.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Joe さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 10
今までの合計 25
