メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Microsoftの最新かつ超強力なゲームコンソールXbox One X(モデル番号1787)は2017年11月7日に発売されました。
How can I fix my eject button?
the eject button on my xbox one x recetnly stopped working. no sound. no eject. nothing. how can I fix this? or is there a workaround? I do know how to manually eject the disc with a paperclip, but that’s not ideal.
thanks!!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
4 件のコメント
Is this a constant thing that happens, the disc drives are usually very forgiving in my experience so conducting a manual eject should be okay.
If it is constant I'll take a look at mine and see how it is hooked up. As long as there isnt any outstanding issues (example being items other the disc being placed into drive, dropped unit, water damage) should be pretty straight forward to either repair replace.
さんによる
it is constant. since last weekend the button does nothing. I manually ejected the disc with a paperclip the other day. It came out fine. I put the disc back in and the xbox pulled it in, leading me to believe that the functionality still works. it just won't eject...
さんによる
Does it make the eject noise when you press the eject button?
さんによる
My son's had two disks in it when I dismantled the whole xbox today lol. Now no noise when I try to eject from console but does take the disk. Any idea?
さんによる
コメントを追加
2件の回答
最も参考になった回答
If your ribbon is not ripped you can fiddle around with the ribbon and it will reconnect to correct placement. If the noise works but still won’t eject from the eject button get crafty and try using tinfoil to the sensor. Literally saved me hella money.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Can you please elaborate on how any of that is done? I have a mental image already just from your description (basically opening up my Xbox and fiddling around with tinfoil), but I'm still unsure. Any help would be appreciated.
さんによる
コメントを追加
I have the exact same problem and through a process of trial and error have concluded the ribbon cable that connects the eject button to the RF board has broken somehow.
I’ve been looking for a replacement online, but struggling to find one. It’s just a case of swapping the old one out. Very frustrating
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Has anyone found a replacement for the "ribbon cable?
さんによる
コメントを追加
回答を追加する
Mario さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 72
今までの合計 6,456
