How to fix a bent back of ipad min?
Accidentally bent the ipad min a little bit. It now gaps a little bit on both side. How do I get it to refit the ipad mini?
At minimum, remove the digitizer and LCD, then use a tool such as the gTools PanelFormer Pro to coax the frame back into straightness, then put the LCD and digitizer back in.
このアンサーは役に立ちましたか?
That is a delicate tool to use to fix aluminum housing, I would just slowly bend the frame and straighten it out with bare hands (with digitizer/LCD and logic board removed of course).
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 594
