メインコンテンツにスキップ
A personal computer that resides in one location with its core components inside a case separate to third-party peripherals required for operation, such as a mouse, keyboard, and monitor.
542回答 すべてを表示
Num lock,caps lock blinking
I have Medion MS-7616.My keyboard worked fine until 2,3 weeks ago,then suddenly num lock start to blinking and keyboard don't working good.When i try typing something or play a game keyboard starts to lag or something like that,example:when i type a letter it continious to typing by itself or when i play a game car starts to moving by itself too.I was reading answers on many forums that is some softver issuses and i try to solve it on many ways like there is describe but nothing works.I know i lot of about a computer and i was fixing so many times issuses on my pc or others but i see something like this for first time.And i forgot to tell,i connected keyboard to other pc and it works fine but i connect again to this pc it start to lags like i said before.So it's some issue in softver for sure but i don't know what.Please if you know how to fix this i will be very grateful
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
Hi @mark1919
Check CPU Heatsink and Fan (Ensure it is not blocked by thick dust)
Perhaps if possible, list out your components e.g.
Processor
Intel Pentium 4, 3.0Ghz HT
Mainboard
MSI MS-7616
Graphics Card
MSI GeForce FX5200
Memory (RAM)
Kingston 2048MB DDR 400Mhz (1GB x 2)
Storage Drive
Seagate Barracuda 7200.10 HDD 250GB SATA
Power Supply Unit
Antec Earthwatts 550
Operating System
Microsoft Windows 7 Pro SP1
さんによる
It's possible.I didn't clean my pc for a long time.My components is:Intel core i3 2.9 Gh,Nvidia geforce gt350 1gb,Main board is MSI 7616,RAM 6GB 3gbx2 don't know it is Kingston or other,and i don't remember what is name of other components,OS is Windows 7 Ultimate.I will check other components as soon as i get home and i will write it here
さんによる
コメントを追加
1 件の回答
ベストアンサー
You said that keyboard worked fine with another computer but has another keyboard worked fine on that computer?
That may sound confusing.
Basically try plugging another Keyboard into the PC that is “having problems”
See if that works, could be a software issue between them two specifically.
If you really love the keyboard try going to Device Manager, finding “Keyboards”…
click on to expand, then right click on your keyboard, click uninstall.
After that, un plug your keyboard. Restart your computer. Then plug the keyboard back in. It will install its automatic drivers for it.
See if it works.
Doing everything I said should give some solution, or some answers at least.
I don’t think it’s a hardware problem at ALL. In which is what some of them are concluding to above.
Most likely a OS issue. If nothing else works, reinstall Windows while keeping files.
Or get a new keyboard (Obviously being if another keyboard works with it)
このアンサーは役に立ちましたか?
スコア 0
7 件のコメント:
That is problem,i don't have another keyboard. I try already to reinstall keyboard but nothing happened,i'm even restart bios but nothing again.However i will try to find another keyboard and do what you said
さんによる
Ok man. Get back to me if you get it to work!
さんによる
Sure.Last night a keyboard was worked fine until morning,then same issue start again
さんによる
I start thinking that virus is problem of all of this,cause my pc was infected by virus 2,3 months ago,but i'm not sure that i was cleaned it
さんによる
@mark1919
Ok if you think that is the issue. Download CCleaner and MalwareBytes (both have saved me from viruses for sure)
You can download free versions for both of these.
Links:
https://www.ccleaner.com/ccleaner/downlo...
https://www.malwarebytes.com/mwb-downloa...
Fiddle with those programs, CCleaner will clean and delete prefetch and unused appdata.
Malwarebytes will search and delete malwares, or viruses.
If that doesn't work, fresh install windows like I suggested previously.
さんによる
2件以上のコメントを表示
コメントを追加
回答を追加する
Marko さん、ありがとうございました!
統計データ:
過去 24時間: 7
過去 7 日: 63
過去 30 日: 208
今までの合計 15,229
