メインコンテンツにスキップ
The Ninja Coffee Bar CF086 is a coffee maker with a 43 oz. Thermal Carafe and Auto-iQ One Touch Intelligence.
9回答 すべてを表示
How do I disassemble the drip stop cup to fix the contact inside?
My drip stop is not working all the time. The trouble light comes on sometimes even when the drip stop is in the open position. So I want to disassemble the drip stop cup/filter holder to clean or otherwise fix the contact inside. How do I take it apart without breaking it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
There is a Phillips head screw in the center of the bottom of the drip cup. Remove it, along with the plastic washer and spring. The drip stop assemble then should pop loose with just some slight pressure. Check to see if sensor activation magnet has rusted out (located inside the tall post at the back of the drip stop assembly).
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Yes it is, what is the best fix? I do not want to buy a brand new Drip cup. Why don't they just sell the drip stop assembly!? It would be so easy to replace. Ninja customer service tried to sell me a brand new coffee maker for $140!!
さんによる
コメントを追加
That portion that protrudes out above your Multi serve cup platform. Tape a small magnet at the bottom portion. You may need to move the magnet around to find the best location.
masinc PVB
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ninja Drip Stopper さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 19
過去 30 日: 118
今までの合計 4,595
