メインコンテンツにスキップ
Repair guides and support for motorcycles manufactured by Yamaha Motor Company.
78回答 すべてを表示
My motorcycle battery is drained after being fully charged?
I have a XJ750 Maxim and the battery drains when I go to start it. I do anything to kill the battery and the is on a charger. It recently started clicking instead of doing nothing. Any advice on what it may be?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Battery is dead, That is why the fast clicking from the starter selenoid. (It doesn’t have the power to hold down the internal spring). Put in a new CHARGED battery & it should start. When running, Put a DC volt meter on the battery terminals. It should be reading 14 ~ 14.5 volts DC when revd up (Charging the battery). If you can’t get 14 plus volts, The bike isn’t charging & the bike will quit when battery runs low enough. As for charging problem, Usually the voltage regulator or stator.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Dakota Kitchen さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 53
