wt1101cw lg top loader
Hello,
My washing machine WT1101CW started to make a grinding sound last week. It sounded more like the plastic teeth on the drive assembly slipping. Not sure. I replaced the entire assembly clutch housing (AEN73131403). Put it back together, same thing. After reading and seeing probably 200 videos and posts, i was sure it was the clutch. Guess not.
I put it on special mode and tried to rinse and spin only. It will try to agitate, but jerk and make grinding sounds like something is not free wheeling the way it should be. I pause it and hit play again. Then it will try to spin, but after a few seconds, it gets stuck and jerks again like something is not letting it freewheel. Then after jerking around for 10 seconds or so, the tub stops and a humming sound comes from the right front of the machine, so I stop it.
I ordered one of the little diverter motor (4681EA1009H) a few days ago. Maybe this is the problem. It seems like maybe the little motor is not moving correctly and causing the clutch to not operate correctly. Thoughts, Ideas????
1件のコメント
I have the same problem. Had you figured out the cause? Thanks
hemitwist さんによる
