メインコンテンツにスキップ
Appleの最新で最もパワフルなiMac Pro。3.2 GHz 8 コア、3.0 GHz 10コア、2.5 GHz 14コア、もしくは2.3 GHz 18コア Xeon Wプロセッサ搭載。モデル番号はEMC 3144 / A1862 (ID iMacPro1,1)。
40回答 すべてを表示
Slow and fluctuating transfer speeds in Finder on High Sierra iMac Pro
Hi, I was wondering if anyone has experienced anything similar.
I bought my iMac pro back in June, and I’ve been experiencing weirdness regarding finder transfer speeds.
I work in data management in the film industry, and while copy / paste-ing let’s say about 700 gb between my fast RAID setup and an external hard drive, the finder will tell me that it will take about an hour to copy these 700gb worth of files.
But then 40 minutes later it’ll say 8 hours or so. Unless I start working on the mac again (move the mouse etc) then the speed picks up again.
And it’s also been slowing down transfers to drives that I just bought.
Is this a High Sierra issue, or is this an iMac Pro issue?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
I would suspect a lack of available “scratch disk” space.
Click the Edit application (Mac) menu, point to Preferences, and then click Performance. Select the check box next to the scratch disk you want to use or clear the check box to remove it. Some applications hold scratch disk space as long as the application is open. To delete scratch disk space you must close the application.
Also how much RAM are you using and is this when using a particular application?
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
As this was just a copy / paste function in the Finder (no application used), I don't think a scratch disk setting would change things (is there such a thing in the Finder? ).
The thing is, if I use terminal to copy the files, this slowdown doesn't happen. It only happens when I either drag&drop or copy/paste in the finder.
I'm beginning to suspect High Sierra.
さんによる
コメントを追加
回答を追加する
benni さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 553
