メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2013年9月10日に発表されたApple iPhone 5cの修理情報とガイドです。モデル A1532, A1456
Can't Set Time & Date Automatically
Hi,
I can’t seem to configure the Time & Date on my iPhone 5C. My SIM is working fine and I get full signal, although when I choose to set time automatically it just hangs on setting the Time Zone. I just get the loading animation next to Time Zone and it never seems to load.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi Donald,
It may be that it’s having trouble with location services. You can try to toggle some settings off and on to see if it will clear it. Also check if location services is even turned on.
Toggle:
Settings>General>Date & Time>Set Automatically (off/on)
Check if location services is on:
Settings>Privacy>Location Services (off/on)
Check if time zone has access to location services:
Settings>Privacy>Location Services>System Services>Setting Time zone option
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
Hi Arthur, Thanks for the suggestion. Unfortunately I have already tried all of these and non of them seem to work. I have also tried a Network Reset and a Full Factory Reset with no luck.
さんによる
I'm sorry to hear that! I wonder if at this point it's a hardware issue. We'll see if anyone else chimes in.
さんによる
Hi Donald. A bit late but did did u manage to fix your issue? I'm having the same problem.
さんによる
@rishkadavids It's a relatively common hardware issue on 5Cs. Impacts on the iPhone creates micro-fractures at the WiFi IC. It can be fixed, although not absolutely reliably, by a reflow or better a reball of the IC. Given present value of a 5C such a repair would cost more than a working 5C iPhone.
さんによる
How set time and date iPhone 5
さんによる
コメントを追加
回答を追加する
Donald さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 35
今までの合計 1,432
