メインコンテンツにスキップ
The QiCycle Folding Electric Bike is Xiaomi’s first foray into the world of e-bikes. It has a 250W high-speed motor powered by Panasonic 18650 lithium batteries. The Shimano Nexus 3-speed gear hub in combination with the torque measurement sensor gives you up to 45km bike power on a single charge. It also has a trip computer can connect to your smartphones via their special app and is–of course–foldable.
54回答 すべてを表示
締切られた回答
Battery is not charging
Hi,
I have a problem when charging the battery, when I connected the charger, the red LED is blinking and is not charging, I wonder is it a problem with the charger or the battery? The bike is only 10 months old and the battery was never flat before charging. Help is appreciated. Thank you very much.
Aidan
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
that sounds like a battery problem. good luck finding a replacement battery tho
Update (11/27/2018)
i found a replacement battery!!
https://www.aliexpress.com/item/Lithium-...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 979
