メインコンテンツにスキップ
Nintendoのハンドヘルドデバイスは2011年2月に発売されました。モデル番号はCTR-001です。
456回答 すべてを表示
3Ds Battery charges for a few minutes then stops
I have a Nintendo 3DS that will charge for a few minutes and then stops. The battery is new (actually i’ve tried 2 different batteries) and I’ve tried 3 different charges that work fine. I have several 3DS systems that all charge fine with these chargers, so I feel I can safely rule out a faulty charger.
I have been able to put a charge to the battery by “stack charging” it. (Plug it in, charge, light goes out, unplug, plug back in……repeat, but who wants to do that!)
I am not sure what is causing it, and would like to see if any of you have experienced this kind of charging problem.
I thought possibly, overheating of the charge circuit? Bad component? (Although I tested the motherboard and did a visual inspection, nothing was found.) It would help if I could find some schematics. Fat chance though, right?
So much fun we’re having.
Thanks.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Fixed. I replaced the charge port and did a hard reset. Seems to work fine now.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
J.K さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 7
今までの合計 254
