メインコンテンツにスキップ
iPhoneの第2世代モデル。モデル番号はA1241 / 8 もしくは16 GBの容量/ ブラックもしくはホワイトのプラスチック製背面ケース。修理はオリジナルiPhoneに比べて直接パーツに作業ができます。ドライバー、こじ開けるためのツールと吸盤カップが必要です。
1169回答 すべてを表示
iPhone3 will not restore, error 1611?
Hi,
Fantastic site. I am trying to fix an iphone 3, that was given to me not working. It only shows the apple sign when i plugged into the computer. It changes logo in dfu mode, itunes recognizes that it needs restoring , but during the installation i get error 1611.
Apple support site suggests that this might be a hardware problem, but no further clues there. I have read some people have had this error as a software problem, but no luck so far.
Tried on different computers using a new usb connector........Id love some help.
Thanks Alistair
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
4件の回答
ベストアンサー
Try replacing the battery or using a powered USB hub
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
Polly is probably right about the battery. But another cause of Error 1611 is your computer Hosts file blocking Apple from signing your firmware. This is a good thing if you are Jailbreaking and Unlocking your iPhone. Anyway you can check if this is the problem very easy. Search on your computer for Hosts. Open the Hosts file and see if any lines have gs.apple.com If so, this is the problem most likely, and not the battery hopefully.
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
yep, I'd agree with that..just depends whether it's a jb phone with a failed restore.
さんによる
brad.. how'd you like to do a guide for all the software/jb problems? click on the feedback welcome at the bottom..it'll take you to metaifixit, bit of a user forum. I think you're far better at the hacking/jb etc...it's a pretty big problem for people too.. (take a look for a link in one of the discussions about pm each other)
I'd email you but you have no info on your profile. cheers, Jen
さんによる
+ I'd like to second that request
さんによる
コメントを追加
Another cause of 1611 which you do not mention is restoring with a Custom Firmware. To restore with a custom firmware you need to be in Pwned DFU Mode, not regular DFU. But since you are not using a Custom Firmware this is not causing the 1611.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Thankyou, thankyou, thankyou ! i stripped it down to the battery and it measured about ten percent of what it should do.........so fingers crossed that i have only one problem. I don't get why Apple don't put this more clearly on their support website, instead of just saying 6011 hardware issue. I will post again when I know I've won. Or not ; )
さんによる
because then we'd be fixing things for 10% of the cost... it's all about the money!
さんによる
Hmmmmmm, i have replaced the battery,and i am still getting the 1611 error when i try to restore the software - same as last time. The phone seems to go on and off a couple of times before it declares this problem.
Also i have searched my computer for hosts and i could not find any files that fitted the description, i have also tired tiny umbrella, but it couldnt find any SHSH files ...........any more help????????????
さんによる
コメントを追加
See if it works when you disconnect the proximity sensor. If it does, you need a different proximity sensor as it is incompatible. I see this a lot.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I tried and i still have the same problem, when i restore the phone goes off and on, off and on, then it tells me i have a 1611 error :(
さんによる
コメントを追加
回答を追加する
Alistair さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 8,802
