メインコンテンツにスキップ
The Epson Artisan 1430 is a color inkjet photo printer.
32回答 すべてを表示
Lack of use caused frozen printer head
The printer has not been used for 3 years and after installing all new ink cartriges
still no success. The little ink jets are clogged I guess. I’m in Oregon and far away
from a repair place - any help here?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi @wrenette ,
Have you tried doing a printhead clean a few times (try up to 5 times), to see if this clears the printhead?
Here’s a link to the user manual for your printer.
Click on Solving problems > Solving Print Quality problems > White or dark lines in printout > Printhead Cleaning and then select the option that suits you best, either from the printer’s control panel or from a computer.
Be aware that this may not work in clearing the printhead but it will consume a lot of ink.
There are also printer repair services that provide printhead cleaning kits as an option that you may wish to consider.
Here’s a link to one such supplier. This is only shown to give you an idea of what it consists of and what the cost is. I have no knowledge as to the effectiveness of their product. If you wish to consider this option there are are other suppliers online that may suit you better. Just search for Epson Artisan 1430 printhead cleaning kit and check the results.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
JULIA さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 3
今までの合計 271
