メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2201回答 すべてを表示
Can I install older iOS's on my iPhone?
I would like to know if is possible to install older iOS on iPhone 4S.
This thing is important because I’ve got an iPhone 4S with 9.3.5 iOS and I noticed that this iOS is really slow, so I would like to downgrade to iOS 7.0 but I noticed that this is not possible because Apple didn’t sign iOS 7.0 or 7.0.x.
So, what is the solution? If Apple didn’t sign an iOS, but if I’ve the file of iOS 7.0.x is possible with another software downgrade actual iOS to iOS 7.0.x?
Thank you in advance for reply.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
If Apple isn't signing the OS it’s impossible to downgrade to a non signed iOS. There isn’t a good way around this, either.
Update (11/26/2018)
So that’s what this is all about?
Exporting IPA files (of Apps) from iOS 9.3.5 of iPhone 4S
Build a NEW iPhone
Restore device with iOS 4.0
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
So there aren't software that can be used with jailbreak and that can downgrade iOS 9.3.5 to iOS 7? Because with iOS 7 is possible using whatsapp, but with iOS 6.1.3 (that is really fast and good for iPhone 4S) not, isn't possible. So, or I downgrade iPhone 4S to iOS 7, or I install whatsapp on iOS 6.1.3, so, what can I do? Whatsapp can't be installed on iOS 6.1.3, or there is a solution about this?
さんによる
コメントを追加
回答を追加する
Patrizio Masini さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 268
