メインコンテンツにスキップ
2012年11月2日に発売された第四世代のiPadです。16、32、64GBモデルがあります。モデル番号はA1460です。
20回答 すべてを表示
iPad 4: Black screen, no charging and not powering on!
I have had an iPad 4 for a while now, I decided to start using it again. I had known that the lightning connector stopped working last time I had stopped using it, and I also remember turning it off at 50%.
When I tried powering it on few days ago, it didn’t turn on or charge. So, I decided to replace the lightning connector thinking it had finally died and the battery had probably drained itself. I used the following iFixit guide: iPad 4 CDMAのLightningコネクタの交換 I was actually able to replace the connector fairly easily following the guide (kudos for that!)
But, when I tried to turn the iPad back on, it doesn’t turn on nor charges. I have tried the following things:
  1. Different charging cable.
  2. Different wall connector of the charger (the thing that slides into the iPad charger).
  3. Charging using a computer + iPad’s cables (in case the charger was entirely broken).
None of these result in any response from the iPad, no battery symbol, no apple logo, nothing. Would anyone have any suggestions for me to try to debug this?
Thank you!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
How long has it been since you had last put it down and stopped using it for a while?
さんによる
Last I powered it down was a month ago. And I distinctly remember turning it off at 50% -ish battery.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
It’s definitely not a battery issue if you had stopped using it for only a month. Sounds like a board level issue going on here, probably a bad tristar IC (U2). I would take your phone to a local and reputable microsolderer and see if they can assist you with soldering a new tristar IC onto your iPad’s logic board.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I will try that and report back, thank you!
さんによる
コメントを追加
回答を追加する
Muhammad Osama さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 270
