メインコンテンツにスキップ
LG's flagship smartphone, with a unique slide-out battery and detachable I/O module supporting multiple hardware expansion options. Released in April 2016.
146回答 すべてを表示
What adhesive or glue can I use to stick the LCD screen to its base?
Hi,
When replacing the power button of my LG G5 the LCD screen got loose from its base and now it has a 2 to 3 mm gap on the left side. What type of tape, or glue, or adhesive can I use to stick it back? Is the iFix film, item code: IF303-087-1, intended for that? If yes, do I have to remove the entire LCD screen, put the film bellow, and then stick it to its base?
As only one corner of the LCD screen has a gap, I am inclined to use tape of liquid glue to deal with that corner only and not to have to remove the entire thing.
Thanks.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi,
I took a risk and used “Superglue” from Locktite, around the inside edges, being careful that the glue does not go past 2 to 3 mms from the edges, allowed it to cure for 24 hours (glue instructions), and it worked! The LCD glass no longer has any opening gap and it looks brand new.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Fernando さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 11
過去 30 日: 64
今までの合計 2,269
