Changed battery, but phone only works when plugged into mains
I have just followed instructions and changed the battery. Now the phone works, but only when plugged into the mains. As soon as I unplug it or try charging from a computer, it stops working. It also seems to be stuck at 31% charge. Any ideas ?
@libbyd25 Do you have a computer running macOS handy?
Aaron Cooke さんによる
Do you mean charging cable?
ConfirmedMars4 さんによる
I Aaron, yes I do have a MacBook on OS High Sierra. But when I plug the phone into the computer it does not work, only on the mains.
Libby さんによる
ConfirmedMars4 yes I do mean the Charging cable. When it is attached to the mains the phone works and is definitely stuck at 31% charged. As soon as it is unplugged, the phone cuts and needs a reboot when plugged to the mains again. It does not work when I attach it to the computer.
Libby さんによる
It's a bad battery from what it sounds. Since phone goes off immediately after unplug the power from the battery is not going through (no power going in or out of battery).
Ben さんによる
