メインコンテンツにスキップ
モデル番号A1288/ 8, 16もしくは32 GB容量
451回答 すべてを表示
Is the LCD screen all I need?
I had an accident to where my iPod Touch 2G screen was cracked but it still worked so I kept using it. I guess once its cracked it can only be dropped so many times before it gets worse. Now my iPod cant recognize when I touch the screen. The picture and color is still good and still clear, nothing out of place or lines on the screen, it just can't read my finger touching it.
I remember reading up on something saying there is like 3 layers of screen in an iPod so im confused....is the LCD replacement screen all I need to get to fix my problem?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
最も参考になった回答
You will need a digitizer, not a LCD, the LCD is the part with the picture, which is working fine. The digitizer is the glass piece that you touch with your fingers. These are very easy to find, i recommend purchasing one with the frame and homebutton already attached.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hi there, what James said is correct. You will need to replace your digitizer. I recommend buying it from ebay.
For the digitizer, click here
Hope this was of help to you and goodluck!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
bridget さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 8
今までの合計 676
