PLEASE HELP! Extreme performance issues
I’m facing very slow performances in Windows only (boot up included). When I am playing games I have no issues. Programs sometimes lag and sometimes don’t. I tried reinstalling Windows, updating all drivers, updating the BIOS, running benchmarking apps to try to find the source of the issue and changing the total paging file size for all drives in the virtual memory and still nothing. I only noticed that the HDD usage is extremely high when it lags. The computer is an ASUS N750JV (i7 4700HQ, 12GB RAM, 2TB HDD, Nvidia GT 750M) running Windows 10. PLEASE HELP!!!
Update (11/25/2018)
The results (images) are attached as you requested jayeff. Safe mode and toggling superfetch had no effect on performance. Sorry for not posting my message in comments, as I can’t add images there.
Update (11/26/2018)
Update (11/27/2018)
Memory diagnostic results
この質問は役に立ちましたか?
8 件のコメント
Does anybody have any ideas? Please respond!
Luka Pranjić さんによる
Hi @crogamer_1 ,
Have you tried starting in safe mode to see how Windows performs?
Try running sfc command to see if the system files are correct.
Are there any events listed in Event Viewer that may give a clue as to what is happening?
Check the value of superfetch just in case there is a problem there.
Just some thoughts
jayeff さんによる
Hi @crogamer_1 ,
What are the 114 Error events listed in Event Viewer?
Click (double click?) on the Error entry row to expand the results and see if they are all the same event ID type.
if they are the same search online using the Event ID info to find out what is the cause of the event.
Usually Critical and Error events are not a good sign especially if it is always the same event.
Warning events are less of a problem although 227 in 7 days is a lot, unless they all happened at once when you were doing something, which may have been the case as there was only 1 in the last 24 hours.
Information and Audit success events are self explanatory.
jayeff さんによる
I looked at the Error entry row and found out that DistributedCOM failed the most (at every boot 1-2 times). Upon fixing the error I noticed that all helll broke loose in the Event Viewer. I didn't notice any performance improvements after applying the "fix". Afterwards, I reverted the changes done to the DistributedCOM error to solve all other errors and warnings. Other errors that showed up in the Event Viewer appeared only once (on the next boot the error doesn't return). I'll keep looking at the DistributedCOM error
Regarding the Warning events, I didn't notice a recurring warning. All seem to be program related
Luka Pranjić さんによる
Hi @crogamer_1 ,
OK.
When Windows lags or when you notice high HDD activity, open Task Manager (right click on taskbar) select Processes tab and check Disk column to see what process is using the most % of disk activity at the time.
jayeff さんによる
3件以上のコメントを表示
