メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2.3GHz, 2.6GHz, or 2.7GHzクアッドコア Intel Core i7 プロセッサ (Turbo Boost 最大3.7GHz) 6MB 共有L3 キャッシュ付き。
Stuck on boot progress bar
Hi,
I have recently replaced the battery in my Macbook Pro . After the battery change I did a boot and the laptop was working fine. So I decided to change the thermal paste too due to the high idle temperatures.
After reapplying the thermal paste I can’t boot into the OS anymore.
When booting I am only presented with an Apple Logo and the progress bar. With a normal boot the progress bar will move to the middle of the apple logo.
In safe mode boot the progress will move up till 3/4 of the bar.
I have tried SMC, NVRAM, PRAM resets, and internet recovery. And nothing seems to be working :
Ran hardware check and there seem to be no errors
Running in Verbose mode it gets stuck on this line
I am currently downloading OS X Mountain Lion and will try boot from a USB. The mac was running on macOS Mojave before.
Any idea what is going on? Is there a chance of a messed up sensor on the motherboard :( ?
Any suggestion is appreciated :)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Start up in Repair Mode and run Disk Utilities;
To use Recovery Mode, reboot or start your Mac and hold the Command and R keys simultaneously on your keyboard as soon as you hear the familiar startupchime. Keep holding as your Mac boots, which may take a few moments depending on its specific configuration.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
While trying to load into recovery mode the progress is still stuck. There are some purple bars running across the screen while trying to boot into recovery. I think there is something wrong with the GPU
さんによる
Do you have the original hard drive? This is sounding like a problem present in the 13" machines. Please check to see exactly which machine you have. You can input the serial number from the back cover here: https://everymac.com/ultimate-mac-lookup...
さんによる
コメントを追加
回答を追加する
De Siang Teoh さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 11
今までの合計 7,435
