メインコンテンツにスキップ
iPhoneの第2世代モデル。モデル番号はA1241 / 8 もしくは16 GBの容量/ ブラックもしくはホワイトのプラスチック製背面ケース。修理はオリジナルiPhoneに比べて直接パーツに作業ができます。ドライバー、こじ開けるためのツールと吸盤カップが必要です。
1158回答 すべてを表示
How to install Flex cable
ok so i need help installing the flex cable into those holders which hold the cable to the phone, the power button has some black holder which holds the power switch, and the vibrate switch as another too do any of you guys know how to put the flex cable into these holders i am having alot of trouble please help
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
3 件のコメント
did the flex you purchased come with the metal parts attached to the end of the flex or do you need to take them from the old one?
さんによる
ps. if you have swapped rear cases sometimes the problem is the machining of the case and the flex isn't the problem...
さんによる
no the flex did not come with the metal parts attached the end, i just need to know how to put those parts to the flex cable
さんによる
コメントを追加
2件の回答
ベストアンサー
this is my least favourite repair...loads of patience needed, lots of frustration. Take a look inside the switch that you use to turn vibrate/mute on and off. You'll see the tiniest of grooves and it is this that you've got to put a tiny piece of plastic switch into from the flex.remember that the red dot is toward the top of the phone on the outer switch..
easiest way of doing it is with some sticky tape or blue tak to hold the vibrate switch from the outside of the phone so that you've got 2 hands free to fiddle about trying to get the tiny plastic toggle on the end of the flex into the groove that's on the vibrate outer switch. You'll need to have the switches both in the down position. once that is in you can put the volume switch in. It's pretty straightforward, no tricks here. The flex folds on itself as it passes around the top of the battery...just lay the flex from power to volume and you'll see that if you were to stretch the flex out it would reach to the bottom of the phone (obviously a silly idea) don't fold it, just double over so that volume controls go in. the upper end of the metal holding the volume button in sits over the top of the metal clasp holding the mute assembly in. lastly the power button... put the metal ring dangling down, it sits on a very small "lip" on the rear case. put screws in and tighten enough to hold power button in...try the button and make sure you have "bounce" if too much tighten a little more, no bounce then loosen. I think there is 1 more screw to secure flex near volume/mute to bottom of case. good luck and happy swearing!
the metal pieces should secure to the flex ends with double sided tape which should be provided on your purchased part. it should be self explanatory. the "nipple" portion obviously sits on the outside of each switch to make contact with the outer button. If it's too annoying send it back and order one with the metal plates attached!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I had a little metal round plate with a hole in the middle fell out the rear panel ? Where does it fit ?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Christian さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 3,229
