メインコンテンツにスキップ
A Panasonic digital camera released in September 2013. The camera features 60x optical zoom and HD video and sound. I see black spots in the lens inside but how to remove the lens to clean. Please help
15回答 すべてを表示
I have broken the on/off switch on my DMC-FZ70 can it be fix
The on/off switch on my  camera is broken can it be fix
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
4件の回答
最も参考になった回答
These switches are built into the control unit and proper fix calls for the entire control unit to be replaced. See guide:
Panasonic DMC-FZ70 Operation Unit Replacement
If you’ve just broken off the tab for the switch and there’s still something to grab onto, you can glue something onto the ring of the on/off switch for easier actuation as a quick fix. If there’s nothing left of the on/off switch the replacement of this portion of the top panel is your option.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
This switch is part of a control unit that can be purchased and is reasonably easy to fit. A video is available.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
The video is online along with other repair tips egg.
さんによる
コメントを追加
You can. Search the part online and get one. Search how to fix it in online. You can get it. I saw somewhere for the same.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
You might try putting in the model number and your zip code on their service center locator, found here: http://www.servicebench.com/templates/ge... unfortunately I can't seem to find parts for that camera, I've always worried about what might happen if I broke that part off on mine, I think I'd 3d print one if my own ever breaks off. If I find anything else, I'll add it to this post.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
rjrjed さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 21
今までの合計 472
