Samsung Washer Top Load AW40J3000 will NOT agitate, spin or Drain
Samsung Top Load Washer AW40J3000… Washer Fills but then it just has a humming sound it will not agitate, spin or drain.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@mamkugs I’d start by checking the lid switch (unlikely) and the belt (Number 1 suspect)that connects the motor to the transmission. A broken belt would cause you to hear the humming from the motor without any movement of the tub.
このアンサーは役に立ちましたか?
Would the washer still spin when draining with this problem
過去 24時間: 0
過去 7 日: 5
過去 30 日: 14
今までの合計 741
