メインコンテンツにスキップ
Appleによるポータブルタブレットコンピューターの全ての修理マニュアルです。修理にはヒートガンや注意深いこじ開け作業が伴います。
Dropped my iPad and now display is green
Hello, people. I dropped my iPad, and now the screen is green and all objects in it seem to be drained. Other than the green color, the iPad is still working normally.
Any help?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 37
17 件のコメント
Is the screen tinted green, or is the whole thing solid green?
さんによる
HI Chris, it's tinted green.
さんによる
Jonas, great job. Now all you have left to do is to accept the answer you got from Chris Green. That way we all know that this worked. Again, great job. ;-)
さんによる
My S3 is also with same problem. .. what to do....
さんによる
Pls help me.....
さんによる
12件以上のコメントを表示
コメントを追加
6件の回答
ベストアンサー
Most likely, the display cable was slightly disconnected when the unit was dropped. You should be able to fix it just by opening it and re-attaching the cable. I'm assuming that it's an iPad 1 (Not an iPad 2), so you should be able to use this guide to open it and access the display ribbon cable.
Once you open it, disconnect then re-connect the LCD cable (surrounded in a yellow box, shown in this picture).
このアンサーは役に立ちましたか?
スコア 12
21 件のコメント:
It worked. Thanks a lot. You guys and this site are great!
さんによる
OMG it worked for me too. Thank you so much Chris.
さんによる
It worked for me! Thanks guys!
さんによる
Hi... Not working for me ... What should I do?
さんによる
OMG Chris it really worked for me. I was like, "yea right." But it worked. Thanks so much!!
Kristia, October 22,2013
さんによる
16件以上のコメントを表示
コメントを追加
最も参考になった回答
To Rogelio,
I just dropped mine about five minutes ago, and all I did was smack the bottom right corner on my knee one good time and it seemed to pop it back into place. There are a few pixels that are still fuzzy, but it isn't bad at all. Not very noticeable, either. I probably will have it fixed later though, just to be safe.
このアンサーは役に立ちましたか?
スコア 27
140 件のコメント:
To everyone (regardless of what version you have). The suggestion by Alex resolved my issue completely (no dead pixels. However, let me clarify. There is no way to tell what corner he was referring to when he referenced, "bottom right." So, I gently hit each corner on the desk and it actually worked. No need to risk cracking it open or paying hundreds of dollars for someone else to work on it. Just gently hit each corner of your ipad on a hard surface.
さんによる
Omgomg really just smack the bottom right and its good as normal... I created an account just to write this review! Hope u all get urs fixed
さんによる
Thank you everybody for all your help! My Ipad 2 turned green and fuzzy a few days ago and I was planning to go to an Apple storento try to get it fixed. I followed your suggestions and just lightly hit all 4 corners on top of a wood counter and it's back to it's original color! Thank you again! This site is awesome!
== Update ==
If you have a few pixels that are still fuzzy, tap all 4 corners and that should fix it.
さんによる
Oh my goodness I dropped my iPad just 3 minutes ago and this helped just tapped each corner and then smacked it on my knee and it went back to normal:) thanks.
さんによる
Brilliant! Just worked on my wife's ipad2. Green screen, now all back to normal.
Many thanks
さんによる
135件以上のコメントを表示
コメントを追加
I read on another site to just slap the back of the iPad. It works as well.
このアンサーは役に立ちましたか?
スコア 7
9 件のコメント:
I just hit the bottom corners and I got my ipad back to normal colors!! Yay...just saved myself $300. I was about to buy a new one in a couple of days.
さんによる
I smacked the back of mine and now it is back to normal!!!
Great Tip! Saved me a trip to the Genius Bar.
さんによる
Thank you man you saved me from making excuse to my mom to get it repaired
さんによる
Omg I slapped the back of mine and it work thank you so much like you save my life
さんによる
Seriously I was like no way the slap would work I was ready to get another one tomorrow morning and it’s like nothing ever happened
さんによる
4件以上のコメントを表示
コメントを追加
This has happened to me before......twice. My brother dropped it from the top of the bunk bed and i dropped it from my bed (not nearly as far). Just smack it on the back a couple of times and it should go away...tap the corners.....or turn it off and drop it on a carpet so it wont crack even more. That should help. :)
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
OH and yeah If you go and get it fixed by Apple they just take it in the back and smack it....
さんによる
コメントを追加
Try this.
How To Fix A Discolored Orange Damaged iPad Screen Quick And Easy
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Ours dropped lengthwise and green screen appeared, tapped on the back but only got blue shadows, so thought to firmly tap lengthwise just to see and it worked! Whatever came loose is now connected, just cannot take advantage and set in a place where it could fall, especially if you have animals that want your attention, place on floor if need be!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jonas さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 20
過去 30 日: 59
今までの合計 247,064
