メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The PowerMac G5 is a desktop computer first produced in 2003 by the Apple Corporation. This guide will review the repair process of an Apple PowerMac G5 model number A1047 EMC 2061 from 2004. It was discontinued in 2006 as part of the Intel switch first to developers then consumers.
The overtemp light is coming on...
Can one add additional cooling fans to a PMG5 which is experiencing overtemp conditions??? Will the addition of more fans help to cool the processors???
Suggestions???
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
1件のコメント
Please give us the last three letters of your serial number so we can identify which machine you have. Thanks
さんによる
コメントを追加
1 件の回答
最も参考になった回答
This model of PowerMac G5 is most likely watercooled. In these models, the coolant tends to leak, and spill onto the power supply, and motherboard. The cooling systems also can fail altogether (The pumps can just die). I recommend that you stop using it, and check inside the case for any spilled coolant, or corrosion (Which is a result of spilled coolant) Unfortionatly, this isn't a problem that you can fix yourself, as swapping CPUs/Cooling units will cause the computer to (In most cases) run the fans erraticly. If cooling leakage is the problem, you should take it to an Apple Store. For a while, they were replacing faulty leaking G5's with Mac Pros, but I'm not sure whether they still do that. For more information, look at the first answer of this question.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Arthur Smith さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 5
今までの合計 924
