part replacement for a HL2040
I need to replace a piece of plastic on the left side of the printer that holds a coiled spring and holds the toner in place. This is for an HL2040 printer
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi @spago ,
This supplier mentions a left and a right pinch spring in the parts list for the printer. (scroll down the list to find the parts)
Unfortunately it doesn’t have a picture with it that perhaps shows if the part is the spring with a plastic attachment or if it is just the spring only .
Perhaps you could contact them and verify if this is the part you need or if not they could tell you what the part you need is called or if it is even available.
このアンサーは役に立ちましたか?
Thanks hope that my printer can be repaired.
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 82
