メインコンテンツにスキップ
Sony Computer Entertainmentによって製造されたPS4と通称で知られるテレビゲーム用コンソールです。2013年2月20日に製品の発表、2013年11月15日に発売されました。
1697回答 すべてを表示
Can this destroyed pcb be fixed?
I don't know, and neither do I want to know what and how the previous owner treated this ps4…
What I know:
-The broken hdmi port has been removed with a drill because they couldn't get the solder to melt…….
-The drill has slipped and hit 2 of the lanes going to the port
-The port has been ripped off taking some pads with it.
I know that soldering a new hdmi port there isn't a problem, but I'm not sure if there is anything that could've been damaged where the holes have been drilled, as the PCB is multilayered.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
That looks very awful..if it was a very valuable board I’d look into schematics to get a clue on where to get traces and make jumpers but from a purely economical prospective I’d say it’s not worth the time and money at a glance..just my 2 cents..
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
Hi .
In my opinion this is fixable … but not as you expected.
In order to have a viable fix in order to use this PS4, you shoul get a HDMI cable ( a cheap one ) but one that has a male an female conector.
The idea is to solder the wires from the HDMI cable directly onto the board - use the end with the female connector.
You cut the cable in half splice it open and with a voltmeter using the continuity test to see wich wire goes to wich pin .
After you solder each wire to the respective pin i woul use the hot glue gun to set everything in place
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Ted Fagerholm さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 6
今までの合計 826
