メインコンテンツにスキップ
Repair and disassembly guides and support for the Digital SLR line of cameras by Canon, including the Eos series first introduced in 1987.
759回答 すべてを表示
What is this part of the LCD screen called? (Canon 80D)
Hi everyone, I recently dropped my 80D on the grass, it had the LCD screen open, and luckily, it keeps working fine, but now doesn’t let me pull it out, as the “rotating” part broke (see photo).
As the screen itself keeps working perfectly well, I was hoping maybe I could get somewhere just this “mount” part, instead of changing the whole thing?
Couldn’t find this replacement part or at leas it’s name anywhere (neither could I find the whole screen kit with this base). Could anyone help?
Thank you very much in advance,
Alex
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Looks like a compression fitting to me. Put the back into place and see if you can press it on.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
@geofocker that is simply called a hinge. Amazingly enough it does not appear to be readily available and when one can be found it is costly like on here
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thank you very much! It is, indeed, what I've been looking for. And yes, it seems a bit costly, but, will give it a try :)
さんによる
コメントを追加
回答を追加する
Alex Krotkov さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 3
今までの合計 397
