メインコンテンツにスキップ
Released January 2016, Identified by model number BDP-S3700
12回答 すべてを表示
Why does the open/close button not work
I have disconnected both the audio and HDMI cable from my device.
After turning on the device, pressing the open/close button has not effect. The green power led is on.
I have tried resetting by holding on the open/close button, and the plugging in the power cord. This did not fix the problem.
Any suggestions or advice would be gratefully received.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@igreid wonder if it is in demo mode. While the player is turned on, press  ■ (stop) , RETURN, (pause), and then the SUBTITLE  button on the remote to disable it.
You can also try to open the case by inserting a paperclip in the hole of the drive
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thanks for the suggestion. This did not help.
This is the second unit I have had this issue with
Not sure what to do next.
さんによる
コメントを追加
回答を追加する
Ian Reid さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 233
